It's been said that new motor oil causes a higher rate of engine wear during the first couple hundred or so miles of use.
The only evidence I've seen presented of this are seemingly high metal concentration from early used oil analysis.
A graph of wear metal vs mileage would show a high slope early on then flattening out at higher mileage.
However, those early metals could come from very small deposits left from the previous oil that get dissolved by the fresh additives in the new oil.
Deposits on non-contact surfaces could entrap metal particles.
So, unless the engine was thoroughly cleaned (hot tanked) when the oil was changed wear metal vs mileage might be misleading.
