Originally Posted By: DoubleWasp
The run is that you cannot use it to convert an R12 system. You can use it in R134 systems legally, so I converted my systems to R134 (without ever putting the R134 in), and then charged them up with ES12a Industrial.
That's another one of those little nuances that makes no sense to me, but none the less it's legal.
If I ever try propane/isobutane in an R12 system, I can always draw down the system, put the R134a fittings on and then either take them right off or leave them(don't guess it matters aside from the chance of someone seeing an R134a fill port and trying to top it up) and then fill with an HC refrigerant.
After all, "retrofit kits" that are legally sold contain little else other than a set of fittings and a can of R134a that claims to use an oil that will mix with mineral oil...
I too consider the use of an HC refrigerant a negligible safety concern. If you're in an accident bad enough to breech the A/C system, having a fuel line break loose and dump gas on the exhaust manifold or catalytic converter is probably a far greater fire concern.
