Finally got my sample analysis back. This fill was mostly 15w40 Valvoline Premium Blue (about 3qts, plus 1qt G-Oil, plus about half bottle ~12oz of Lucas oil stabilizer). Things are certainly getting better. I guess I agree with Blackstone's comments that aluminum could be lower.
Frantz bypass filter was installed about half way through this OCI. Oil was drained from the sump and I refilled with Rotella T6 and plan to go about 3,000 before sampling again. I am very encouraged by the Insolubles number, and attribute that to the Frantz filter doing its job.
Where'd the titanium come from? I believe the silicon is from sealants and the silicone PCV kit I installed when I rebuilt the engine so I don't think it's from an air intake leak.
Code:
Mileage 174k 175k 176,200
OCI 10k 1k 1200
Oil PYB 5-30 Zblend Zblend
ALUMINUM 12 13 6
CHROMIUM 2 2 1
IRON 56 28 11
COPPER 15 4 3
LEAD 2 1 1
TIN 8 3 0
MOLY 85 61 43
NICKEL 2 1 0
MANGANESE 1 2 1
SILVER 0 0 0
TITANIUM 0 9 13
POTASSIUM 4 0 2
BORON 39 89 33
SILICON 26 18 16
SODIUM 14 12 6
CALCIUM 2276 1746 1363
MAGNESIUM 15 393 345
PHOSPHORUS 816 900 798
ZINC 963 1033 906
BARIUM 1 0 0
cSt100 9.52 11.27 14.05
SUS Visc 57.6 63.8 74.2
Flash°F: 400 405 410
Fuel %:
Coolant%: 0 0 0
Water%: 0 0 0
Insol%: 0.3 0.3 TR
TBN: ? ? ?
Blackstone's comments:
Things look a little better after this 1,200-mile oil run, but aluminum and silicon could stand to read lower. We won't complain too much since this is the lowest both have read in the sample history, but we'll look for them to continue this trend in the next sample. It may not be a bad idea to double check the air intake/filter for any leaks that might allow unfiltered air into the engine. The viscosity was thick, mostly from the Lucas, but that's okay. No contamination was found and insolubles only read a trace. Once things clear up, a normal interval is an attainable goal.
