Originally Posted By: PimTac
How do you know this is due to cost cutting? The specs are still within the requirements for d1G2. While Noack is important it is only one aspect of the oil.
But why does Dexos make it such a big deal? That only applies to GM engines, not the dozens upon dozens of other engine manufacturers out there.
Anyone who owns a TGDI or a GDI engine should be using the newer spec oils to reduce the possibility of LSPI.
^^^THIS!
I take the D1G2 spec as an absolute minimum for oil I will put into an EcoBoost engine.
IF an oil 'meets' the D1G2 NOACK spec, but is still over 9%, I will NOT use it!
I want to use an oil which beats that spec BY FAR in EVERY catagory, yes, even if the VERY many naysayers, and 'frugal minimalists' who abound on here claim "You don't need it".
MY car/engine, MY choice, despite their 'opinions'.
^^^THIS!
