quote:
TSB No. TS 02 01074
Division: Automotive Section Title: General Info
Category: Technical
SUBJECT: CORRECT COOLANT USAGE
MODEL(S): ALL MODELS
YEAR: 1986 - 2004
There are three (3) basic types of coolant available in the market today. Ethylene Glycol Silicate Based, Ethylene Glycol Phosphate Based, and Organic Acid Based. The color of the coolant has nothing to do with the actual base coolant and is only the dye added by the coolant manufacturer.
The only way to properly identify the type of base coolant is to READ THE LABEL.
For our new Verona and Forenza vehicles(NOT MY CAR), the proper coolant to use is the Ethylene Glycol Silicate
Based coolant. The proper mix is 50/50 coolant to water* and in no case higher then 70/30.
Concentrations greater then 70/30 coolant to water will cause overheating conditions.
For all other Suzuki automotive products, the proper coolant is the Ethylene Glycol Phosphate
Based coolant. Again, at a 50/50 coolant to water* mix, not to exceed 70/30.
*It is strongly recommended that either distilled water is used to mix with concentrated coolant or a
"pre-mixed" coolant is used. This is especially important in areas where the tap water has a lot of dissolved
minerals (Hard Water). The presence of an abundance of dissolved minerals may cause the
Silicates or Phosphates to drop out of suspension and cause cooling system malfunction. (i.e. rapid
seal wear, block corrosion, passage way and/or radiator blockage.)
WARNING:
DO NOT MIX DIFFERENT TYPES OF BASE COOLANTS. MIXING DIFFERENT BASE COOLANTS
MAY RESULT IN ACCELERATED SEAL WEAR AND/OR THE POSSIBILITY OF SEVERE
OVERHEATING AND EXTENSIVE ENGINE/AUTOMATIC TRANSMISSION DAMAGE.
