Using an oil filter for HYDRAULICS (Wix?)
North Texas
Tough to get a replacement hydraulic filter, when I can, it is expensive and cheaply made.
Just a thought, If I can get the thread, gasket to fit, what am I risking in using a high quality (say Wix?) oil filter?
thanks!
terry
Is it a pressure side or return side application?
Do you know the OE part number? If you do you can look it up on the Wix (or any other mfgs. web site).
Those being asked, the answer is a definite maybe.
This is the firs set of 50/5000 for kubota off road equipment.
In order to get there from here you'll have to "sign up" on the Wix web site. The link is in the lower right portion of the opening page. ( www.wixfilters.com ) once you sign on follow the links to "off road" equipment and you'll get there.
Most likely your application is a Wix 51064. But there are other applications too, 51361, 51268, 51344 etc.
Sub-Make Model/Engine Oil Air Fuel Trans. Hyd. Other
Tractors AM3300 w/Kubota V1505 Engine 51344 33390
Tractors B1550 w/Kubota Engine 51064 46387 33389
Tractors B1550D w/Kubota D850-5B Engine 51064 46387 33389
Tractors B1550DT w/Kubota Engine 51064 33389
Tractors B1550E w/Kubota D850-5B Engine 51064 46387 33389
Tractors B1550HSD w/Kubota D850-5B Engine 51064 46387 33389
Tractors B1550HSE w/Kubota D850-5B Engine 51064 46387 33389
Tractors B1550HST w/Kubota D850-5B Engine 51064 46387 33389 51367
(Hydrostatic)
Tractors B1550HST-D w/Kubota D850-5B Engine 51064
51361
6602136060 (Hydrostatic) 46387 33389
Tractors B1550HST-E w/Kubota D850-5B Engine 51064
51361
Tractors B1700 w/Kubota D905D10 Engine 51064
51387
(Hydrostatic) 33389 57089
6795537710
Tractors B1700DT w/Kubota D905D10 Engine 51064
51361
6602136060 (Hydrostatic) 33389 57089
6795537710
Tractors B1700E w/Kubota D905D10 Engine 51064
51361
6795537710
Tractors B1700HSD 51064 33389
Tractors B1700HST w/Kubota D905D10 Engine 51361
(Hydrostatic) 33389
Tractors B1700HST-D w/Kubota D905D10 Engine 51064
51361
thanks! I missed the "sign-in" and have been stumpling on the "public" mode.
here are the Kubota Tractors with this hydraulic filter:
B-Series - B2150D, B9200D
L-Series - L2250, L235, L2550, L275, L2850, L3250
Originally posted by Pete C.:
[QB]
oops,
worked once, when I went back to confirm, got the following on all searches (10 vehicles)
Microsoft VBScript runtime error '800a0009'
Subscript out of range: '[number: 9]'
/products/filterlookup/CommonOutput.asp, line 48
