Quote:
Yes. An EaO is a hard sell if you're not (at least) willing to do extended filter changes even if you're following shorter oil sump changes. That goes for any filter. If you're renewing the sump on a 3-5k basis AND insist on changing the filter every time, then there's not much payback in terms of cost:benefit from expensive filters. The view can be altered by total annual mileage. Someone doing 8k a year with 6m/5k recommended changes vs. someone doing 15k+/year doing 5k changes.
I agree. It just doesn't make sense to use a filter designed for extended OCI's when you are changing the filter every 5K.
