The original bearing in the car has an outside diameter of 60.3 mm like NSK 47TKT3101B,
the new one I got in a clutch kit is 65 mm like NSK 47TKB3102A,
The inside diameter of 31 mm is the same on both.
The diameter of what rides on the pressure plate is the same on both.
The width of the hooks where the fork attaches is the same on both.
Any reason I can't use this? NSK lists the two separately, https://nsk.incony.de/web/na/en_DE/PKW/45/4577/14410/applicationSearch.xhtml
