I'm working on my girlfriends 2003 mazda protege LX 2.0l. I'm replacing the clutch and several things that need attention. I got the clutch kit an exedy KMZ08.
The problem is that when I got the transmission on and went to install the slave cylinder, I noticed the release fork was near the end of its travel. I suspected the throwout bearing being in backwards, that wasn't the case. The clutch cover/pressure plate and pilot bearing are identical and spec exactly the same as the stock ones. It seems that the clutch disc is too thick making the diaphragm spring fingers all just about parallel to each other.
Is there any other cause to this problem because the clutch disc just looks like a not worn-out one of the one that came out of there?
