Topping off with used oil
A stretch? I was trying to make a point - very poorly, I guess - that if 80% of your oil can go longer than 5k, then add a fresh quart and extend your interval. Why drain that oil only to retain it for future top-offs? With my suggestion (80% old oil with 20% new oil) you should be able to extend your interval by a ratioable amount; based on your normal 5k OCI, which may be too short as-is, 20% longer with 20% fresh oil sounds pretty fair.
Unless you're using a really terrible filter, changing your oil despite your filter doesn't make any sense. I an OEM Subaru filter, which is of adequate, but not stellar construction, for ~7k intervals in a turbo-charged Subaru and have not had a UOA come back with high insolubles.
If you'd like to add a used quart of oil, by all means, go for it. If you'd like to post about it online, then expect some feedback. I apologize for my initial response, but the OP seemed so out there that I couldn't help posting something sophomoric.
not quite, he drove the truck till the the wheels started falling off literally speaking. the engine got used oil and cheapest store bought he could get.engine leaked and burned oil. still ran on it s way to bone it,not much else worked.
