Originally Posted By: Hokiefyd
Originally Posted By: CapriRacer
Put another way, straight ahead driving is practically free.
This has to assume a very neutral alignment, right? An alignment set up for good handling/response may have a moderate amount of toe, and in this case, the tire will always be in a scrub as it rolls down the road...even a straight road, right?
My experience is that toe doesn't add to handling - only detracts. Camber on the hand can add to handling, but it is extremely sensitive to the toe setting - toe acting as a multiplier relative to tire wear.
And here's where it gets tricky and problematic.
Many race cars that are converted street machines will use the toe setting to compensate for the Ackerman - the difference in toe angles when the steering wheel is turned. If you are cornering a car hard, you need less Ackerman than if you aren't. Street cars are set up for light levels of cornering and cars converted for racing purposes benefit from fixing the Ackerman. And if you can't fix the Ackerman, setting the toe to "toe out" is one way to get the proper toe when cornering.
But you are right. Driving a car straight ahead with a bunch of toe-in in the front tires just wears them out quicker.
