Originally Posted By: Wolf359
Originally Posted By: mattwithcats
And what pressure did Ford originally specify for the Explorer?
Drum roll, please....
"After the Explorer rolled over in company tests prior to production Ford decided to lower the suspension and remove air from the tires to 26 psi compared to 35 psi for the same tires on the Ranger."
So because of Ford doing something dubious with one vehicle, it negates the validity of the process for the entire industry?
What thoroughly vetted protocol are you offering up as an alternative to what the OEM provides here then? Because your previous post hints at your process basically involving using OEM as a minimum, sidewall as the max and tossing darts to arrive at some intermediate value...
I'm not sure exactly who was really to blame on that. Not sure it was 100% Ford or Firestone. But I believe it was a bad combination of hot weather, over loaded vehicles, long trips, under inflated tires and defective tires. Since then, you have tire pressure monitors and not that many defective tire recalls.
