Time for an oil survey?
1987 BMW R65
Castrol Edge Sport 25/50,OEM filters.
I have Silkolene Pro 4 15/50 in the 1987 TLR 200 as it gets a hard time in trials,but I haven't used it in 2 years.When I get back into it I'll probably used the Fuchs HDEO.
Originally Posted By: crazyoildude
Motorcraft in the fords pyb in most of the others as for filters oem ford or p1
Ford makes a motorcycle? I think not -- just motorcycles guys, not your cars or trucks....
Originally Posted By: sbergman27
Mobil 1 EP 5w30 oil
Bosch Distance Plus filter
Changing of the factory Toyota WS ATF is not listed in the maintenance schedule at all... which goes all the way to 120,000 miles.
No Toyota motorcycles either.....
Originally Posted By: bigbird_1
Shell Rotella T6 5W-40
No filter, engine uses a strainer
Same here, Rotella T6 5w40 Syntheitc.
2 scooters and a Yamaha XS-650
Gear Oil = Mobil 1 75w90 Synthetic.
Rob
Generally this is what I do:
2 Stroke premix street & dirtbikes = Klotz Supertechniplate (20% castor).
2 stroke injection street bikes = Klotz Techniplate.
2 stroke racing MX gearboxes - Redline 80W with "shockproof." The best stuff I've ever found and I've tried tons of different lubes.
2 stroke street gearboxes = good quality 40 weight HDEO like Chevron Delo or Rotella. If I have some motorcycle 4-stroke oil available, will use that too. Street bike two stroke gearboxes are generally not too demanding on lube.
4 stroke air cooled street bikes - 10w30 or 5W-40 synthetic HDEO like Delo or Rotella, or, if its on sale, Mobil 1 10W-40 motorcycle synthetic or Klotz 10W-40.
Delvac 15w40 in my ATV's
2 Harley Twin Cams (02 Deuce, 04 Lowrider):
Redline V-Twin with OEM H-D chrome filters
84 IronHead Sportster 1000cc
Mobil 1 15W/50 with OEM H-D chrome filter
Laverda 1000 Jota, 1974 Back in the 70s and 80s, Kendall GT1 20w50. Mothballed for twenty years and returned to service in 2005. Was run with Rotella 15w40 or 5w40 depending on the time of year. Since the Rotella now is CJ, it enjoys Brad Penn MC oil, 20w50. No oil filter fitted from the factory, uses a fine screen in the sump.(like early air cooled VW)
The engines will go 100k+ if you change the oil often.
Nice bike, my relatives always are telling stories about the Jota, the worlds first superbike! Do you have any pics?
OK, back on topic...
1990 FLHTP- Amsoil 20w-50 and Amsoil filter.
1990 FLSTC- Revtech 20w-50 and Revtech filter.
1997 FLHRI- Revtech Pure 20w-50 and Per-form filter.
1999 FXST- Revtech Pure 20w-50 and Revtech filter.
I have some pics. Not sure how to post them here. I will research and see if I can put a few up.
Thanks
