AKA The Tar Pit. Presumably due to blowby, so maybe a compression test and/or catch can are indicated, although it might not have been done for 30 years.
Its had regular squirts of carb cleaner down the intake, but I've never been very convinced by carb cleaner.For this job I've been using brake fluid for cleaning, which (touch wood) seems to be quite a lot more effective.
I don't have a manual for this car but I have a scan of the G10 manual. This carb (AISIN Model 87773) seems to be very similar, but the photos are of the "remove tiny black dot from somewhere in the big grey fuzzy mass" school of photo-impressionism.
I couldn't remove all the ancilliaries. The cross-heads just cammed-out, and I didn't want to try my hit-it-with-a-hammer impact driver on a carb casting.
Perhaps this would be a job for one of the electric impact drivers Americans are so fond of (in which case I'll have to stop sneering at them)?
I couldn't (so far) remove all the jets either. The manual says "it is mandatory to employ the special carburetor screw driver set, carburetor adjusting gauge set and wire guage set" which is too bad, but I did tell myself I wouldn't try anything with ill-fitting tools.
I didn't have the right screwdriver for the needle valve seat, which should be fairly easily addressed, but its a 40K round trip to the nearest half decent tool shop.
The other 3 jets I can't get off are shown in the photo below. The slow jet (brass thing in the curved recess in the side of the float chamber) looks like it needs a rather slim box spanner or long socket. The primary and secondary jets are in the bottom side of float chamber, and would be accessed by removing two plugs in the opposite side. I couldn't exert enough force on these to shift them.
My options for that seem to be:-
(a) put the carb body in a vice, if I can get access to one. Bit scary, though the base seems quite strong.
(b) bolt it back on the car to anchor it. Also a bit scary, but better.
(c) Boil it, in the hope that the heat will loosen things up.
This would be favorite (and is my standard method with motorcycle carbs) but I don't want to boil the vacuum-pot ancilliaries which I can't get off.
I've done a couple of simple motorcycle ones (Kymco Zing 150cc Honda CG125 clone, and Yamaha RZR 133cc 2-stroke) a few times and had evolved a technique involving boiling with automatic washing powder, and then blasting the passages out with first the detergent, and then alcohol. The latter gets around the lack of compressed air, the former the fact that, in my limited experience, the sludge in motorcycle carbs here was mostly a greyish mineral-looking deposit (maybe a corrosion product?) which carb cleaner didn't remove. Carb cleaner seems to be intended for tarry or gummy organic deposits, which is what this car has.
The jets I can get to so far seem pretty clean though, so while cleaning the tar out is nice, I doubt its fixing anything.
