SHOZ writes:
quote:
I use the plain green stuff in my all aluminum '97 Taurus engine. Usually change it out every year.
Good choice, good plan, SHOZ. Conventional silicate formulations protect aluminum second to none.
jef1ge writes:
quote:
I am starting to use a low silicate conventional, namely "Peak" . . . it complies with ASTM d4985, so it should
be good for aluminum engines as well as cast iron.
Excellent analysis. Peak "Classic" is a patented low-silicate high-tech "conventional" formulation highly protective of aluminum. See US patents 4,426,309 and 4,382,870 for an eye-opening and interesting read.
Peak is manufactured by Old World Industries, the second largest
supplier of antifreeze in North America. OWI is also the number one producer of private label antifreeze, including (but not limited to) AutoZone Valucraft, True Value, "Manny, Moe, and Jack" ProLine, and TSC Traveller. If the label says silicates
and phosphates then it probably is re-branded Peak "Classic", a high quality product.
Kestas wries:
quote:
Antifreeze is presently undergoing an evolution. Most modern formulations are better than the old green stuff
True enough.
All antifreeze has undergone an evolution. In fact, you would be hard pressed to name a manufacturer of "old green stuff" let alone buy some. "Old green stuff" is largely a strawman which no longer exists. To be sure, there exist green dyed silicate based coolants, but these are not your grandfather's antifreeze. Time and chemistry march on.
Pitbull writes:
quote:
The 4.7 V8 has the iron block and aluminum head so in case any residue is being shed I want to be extra careful. What do you guys think of my plan?
Your maintenance plan is excellent. However it is your obvious meticulous attention to system integrity which will serve you better than worrying about the chemistry of your antifreeze.
It is interesting to note that from a reading of widely available ASTM test results, formulations which contain silicates (whether conventional or hybrids such as G-05) actually provide somewhat better protection to aluminum engine parts. But rather than split hairs, the fact is all major coolant technologies do a highly respectable job of corrosion protection in gasoline engines, and certainly all of them fall well within ASTM limits. System maintenance is the real key.
With aluminum heads it is critically important to guarantee that all air is bled out of the system and that the coolant level remains higher than the top of the head. Aluminum heads are not tolerant of air pockets and low coolant levels. And while some chemistries may be marginally more tolerant of air in the system than others, keeping the air out is an excellent idea for
all formulations. It is particularly important with newer OAT technologies like Dex-Cool and others.
Optimal cooling system performance demands
zero tolerance for leaks, weeps, seeps, and drips. No cracks in overflow tanks and lines. No loose hose clamps. Air can not be allowed to find a way into the system. If someone finds that he is routinely topping off an overflow tank, he must discover where the coolant is going and fix the problem. If the radiator seeps, fix it or replace it; it is cheaper than replacing a head.
