Does anyone have experience with tape pinstripe removal? I did it once before on an older car and I was able to easily remove all of the pinstripe with no trouble.
I bought a car recently and noticed the pinstripe is deteriorating on the driver side toward the rear of the car. It has cracks through it and looks thin. So I used the same technique I did last time, hair dryer with a soft plastic scraper to lift the pinstripe. I started on the driver side, the side that had the deterioration toward the rear.
Starting from the front I removed the pinstripe at a good clip and it looked great underneath. As I started to remove the deteriorating pinstripe toward the rear is when things started to go terribly wrong. Every time I would lift the pinstripe, I would see some black under the pinstripe. The car's color is Modern Steel Metallic which is a metallic gray.
This black under the pinstripe is my big issue, I have no idea what it is. As the deterioration increases toward the rear of the car, the amount of black being exposed increases as I remove the pinstripe.
1. Looking at the light the black appears raised but I can't tell if it's just the line the pinstripe makes in the clear coat. It looks like some kind of adhesive but it's as shiny as the clear coat is, no color transfer occurs and acetone does nothing to it. Acetone dissolved the other adhesive toward the front with no problem so I don't see why it wouldn't work here unless this was some extremely hardened adhesive.
2. I tried some SwirlX to see if it was above the paint or something, no color transfer, no difference.
3. Clay bar does nothing as well.
4. I can just barely grab it with my fingernail, slides past it.
5. This car is a 2015, the pinstripes haven't even been on there that long. I've removed pinstripes of this same type from older cars with no issues.
At this point I'm a little upset. If I can't fix this I'll either have to paint over it or get another pinstripe and put pinstripes back on.
I don't see how the tape pinstripe could have damaged the actual paint under the clear without damaging the clear itself since the clear is still there and shiny. I don't even know what this black stuff is. Should I be using something other than acetone?
Here are some pictures of what I'm dealing with. I hope this shows that the black stuff is as shiny as the clear coat and almost uninterrupted when looking at both the black stuff and clear coat. It appears the black stuff is only under the white parts of the pinstripe, because where the pinstripes have cracks, the black stuff also has cracks.
