Best oil thread!!
Amsoil Euro 0W-30
Amsoil Euro 0W-30
New users are having to get creative in starting a thick vs. thin or "best oil" thread these days. All the easy pathways are too obvious.
This hits both.
It's as if forums were made for discussion and learning. I understand I can search, because I do/have A LOT. But cars/motors change, certs/oils change so info changes.New users are having to get creative in starting a thick vs. thin or "best oil" thread these days. All the easy pathways are too obvious.
This hits both.
Go to the MSDS for that particular oil. Look for the pour point and the flash point.I'm just worried about excess wear from running 0w20 when oil temps get 212-230 often here in the georgia summers. How do you find what temps oils can get to?
Most are around 230-240c which is well above my oil temps. But whats a good level for both?Go to the MSDS for that particular oil. Look for the pour point and the flash point.
Two of the most inconsequential attributes.Go to the MSDS for that particular oil. Look for the pour point and the flash point.
So what do you recommend looking at for high temp operationTwo of the most inconsequential attributes.
That Castrol 0w30 you mention is SL.
An oil with an approval that demonstrates high temperature oxidation stability, as well as resistance to deposit formation, ring sticking and varnish. Something like an ACEA A3/B4 oil with Mercedes-Benz 229.5 or VW 502 00 approval. Or the Mobil 1 ESP also mentioned. That's one of the best oils avilable anywhere.So what do you recommend looking at for high temp operation
It's more effective/ efficient imo to ask specific things like I did vs going across 4 different old threads. If there's no rule against creating new threads, you could just ignore.You cannot discuss in former threads? Why? You can probably learn even much more from reading existing threads. Yes, there are LOTS. Cars, certs and oil change? Significantly compared to one or two weeks before? Actually?
Your pistons and pistons rings are subject to 400°-500°C. So yes, your oil is susceptible to higher temps well above flash temp.
There's 24+ years of history. Formerly by previous forum owners, "Best Oil" threads were forbidden. We sometimes have fun with that.It's as if forums were made for discussion and learning. I understand I can search, because I do/have A LOT. But cars/motors change, certs/oils change so info changes.
I have found the newest M1 5W30 EP D1 / Gen 3 rated Synthetic oil to be surprisingly quiet in my otherwise noisy Hyundai Sonata - this could make for a good choice (don’t extend OCI beyond what your OM calls for).It doesn't matter and won't do anything for you if you switch from an ILSAC 0W-20 to an ILSAC 5W-30. If you want an improvement then switch to something like Mobil 1 ESP 0W-30 or 5W-30, or something similar, like PP Euro LX 0W-30, PP Euro L 5W-30, etc. Otherwise just stay with a quality 0W-20.
If you want to use one of the oils provided in your list, then PUP 5W-30 is the way to go. Castrol EDGE EP is another great choice.
What're your thoughts on QSUP?It doesn't matter and won't do anything for you if you switch from an ILSAC 0W-20 to an ILSAC 5W-30. If you want an improvement then switch to something like Mobil 1 ESP 0W-30 or 5W-30, or something similar, like PP Euro LX 0W-30, PP Euro L 5W-30, etc. Otherwise just stay with a quality 0W-20.
Here's a few previous threads to get you started on this brand. Some are quite long and detailed.What're your thoughts on QSUP?
