Streamed music through older speakers
I am using a red and white Y plug to adapt the 1/8" line to the amp via twin RCA plugs
I use the same 1/8" plugs and line, sans the Y adapter, to play through the Tivoli.
Originally Posted By: expat
Hmm, thanks guys.
I plug the tablet into out Technics amp/tuner via the headphone jack.
I have tried ALL the input recepticles, but the volume is very low* unless I really crank up the amp, and then sound quality suffers. Even when the tablet volume is turned to the max!
Strangely pluging into the Tivoli's aux input gives very good results. But of course the volume is limited to the little radios output.
I'm betting it sounds lousy because the headphone-output driver ckt is designed to only drive a high-impedance, when you connect it to a line-level input on a receiver, the low impedance overloads the little heaphone output stage, resulting in high distorsion. What you need is a buffer ckt with a high input impedance and a low output impedance + some gain. It's easy enough to build one with an op-amp or a few transistors, but may be more than you're looking for.
High impedance headphone output drivers are not up to the task of driving a line-level input.
Originally Posted By: MolaKule
Your garbage music problem is caused by an "impedance" mismatch.
High "Z" or low "Z" ?? .... let's Z
Your problem may be in the adapter then. It should really sound no different between those two devices.
Thanks to the posts that I have received, I'm begining to think the same thing.
It's a good place to start.
