The ABS pump/actuator/servo engages randomly. I can hear it engage. When it does this, the speedometer needle jumps around all over the place.
Sometimes, when this happens, the yellow ABS light and the red BRAKE lights illuminate, and sometimes they don't.
Obviously this has the potential to negatively impact stopping distances.
Anyone run into this before?
Incidentally, what IS that whirring noise when ABS engages?
Why would the speedometer needle jump around?
*The back story is that, last fall, the yellow ABS and red BRAKE caution/warning lights came on as a result of a worn out LH rear wheel bearing that developed enough play that the speed sensor for that wheel, which is mounted in the housing for the wheel bearing, was actually being chafed and destroyed, which caused the light. I ended up replacing both rear wheel bearings, axle seals, and that sensor, and the lights went off. Now they are coming on again, albeit intermittently.
Threads here:
https://www.bobistheoilguy.com/foru...ke-warning-lamps-illuminated#Post4922830
https://www.bobistheoilguy.com/foru...g-chafing-wheel-speed-sensor-2007-tacoma
Threads here:
