We’ve had a few discussions on Oil Sands Wells in Canada. Some included heated discussions ( don’t mind the pun.) Currently half the production is from open pit mines, but the other half is from pairs of horizontal wells drilled from pads. It’s called steam assisted gravity drainage. (SAGD), pronounced sag-D. The lower well is the producer and an upper well is a steam injector. steam is applied in the upper horizontal wellbore and the thick oil is heated and its viscosity is lowered enough for it to flow into the lower wellbore where it is pumped to surface. The majority of the oil reserves in the Oil Sands area is too deep to use open bit mining. I’ve included a aerial photo of a 12 well pad with 6 oil producers and 6 steam injectors. The six vertical objects to the left are the vertical sucker rod pump jacks ( different from your standard looking pump jack). The item on the far right is the steam production facility. Hopefully the photo loads. If not I’ll load it later. Enjoy.
Didn’t Load. Later.
Didn’t Load. Later.
