Spraying Petroleum: WD-40 spray bottles?
JHZR2
Staff member
New Jersey
One of the ways I apply anti-rust products is by spraying. I currently have a few Corrosion-X and LPS 3 bottles I use.
Aerosol sprays are too messy and the actual nozzle section tends to leak all over if spraying for a while. Case in point, CRC 6-56 made a huge mess all over my hands when I was spraying it.
Ive seen some HD spray bottles at Amazon that have viton innards. But Ive also noticed the WD40 spray bottles at HD are designed to spray petroleum products.
What does anyone use to spray oils/solvents by hand? Does anyone have experiences with those $2.99 WD-40 bottles, good or bad?
They have a fill port on them which is interesting...
One thing I should mention: There's a little plastic tang that you have to push down in order to turn the nozzle away from its OFF position. A small pin punch is ideal.
