I'm not sure what the blow is against top tier?
Many of you know that I'm not a fan of top tier and consider it a marketing ploy.However, all grades meet the Top Tier requirements.
I don't think this is accurate. It is 5x the EPA requirement, which would be higher than min top tier requirement, but probably in line with others.Costco has 5-6 times more additive than regular Top Tier. I think it's mostly marketing by Shell then Exxon had to catch up.
If the lesser additized fuel meets top tier, then what would you call the premium grade? Top Top Tier? Oil companies typically use the amount of additive mandated by the EPA. Only saw additional additives used in a very small number of cases.
It's been a long time since I've run across a company willing to spend more money than necessary, particularly when the profit margin is so slim, and especially during these times of economic uncertainty. Pretty sure I just read that Exxon just cut the company match on the employee 401K plans.I guess you are claiming that companies are not following their Top Tier designation and only using the EPA mandated amount?
That is kind of a bold claim.
You can make more markup on a twinkie than a gallon of gas.
Besides, how would anybody know? The State agencies can barely calibrate and test the dispensers to deliver the correct quantities of product. Last I heard (10 years ago) most states were "working" on being able to check octane ratings.
Just sayin'
Exactly...there's way too many steps in the process for everyone to be lying/cheating.But the big deal is that the pipeline/terminal operators are hardly ones that want to get in trouble for helping anyone cheat. They rely on getting industry standard fuels and their equipment meters everything properly.
I was not referring to terminal or pipeline operations, but the stations themselves, which are monitored on the County level.
And I'm not inferring that terminals cheat, since that is where the additives are actually put in the fuel. They all have very capable meter testing equipment and ensure the accuracy on a regular basis. Including the accuracy of the additive meters.
All I'm saying is that stations can advertise whatever they like, including Top Tier, and there is no way that anyone can verify if it is being adhered to or not. There is also no standard, so what IF the fuel doesn't meet Top Tier add content....nobody knows what it's supposed to be anyway.
It's "branded" as soon as it receives the specific additives at the proper level specified by the fuel marketer. I know that the base fuel itself is a fungible commodity.What is "non branded fuel"? All gasoline is shipped as fungible barrels, it doesn't become "branded" until the additives are put in at the loading rack.
I had 4 additive tanks at one of my terminals, Chevron, BP, Exxon, and Afton Chemical. All the gasoline was the same until it hit the tanker truck. Recipes for all stations did not vary by location or individual station. If it was BP, (as Supplier) it was getting BP additive and the correct amount for each octane (premium getting a little bit more) but the name on the station didn't need to be BP. It could be Kangaroo, etc.
Still doesn't tell me what top tier is, nor does it specify what performance improvements I can expect to get. It's a "Just trust me, it's better" kind of thing.
