I currently own a 2015 Lexus GS 350 AWD. Manual calls for 75W85 GL5 for the rear diff and 80W-90 GL5 Hypoid for the front diff.
Was planning on using Redline 75W85 for the rear and Redline 75W90 for the front. Any concerns or possible problem with the different viscosity of the Redline for the front?
Second question. I do not own a lift and cannot slide under the car without raising the car 5-6" . I normally use solid wood ramps that I built layering 2x8's joined with liquid nails.
If I use these ramps to raise the front end (or the rear end) the car will obviously not be level. Any issues draining and refilling using this technique?
Thanks for answering these probably elementary questions.
