I have often thought it would be good to find a filter element that was as good as TP with the capacity of paper towels. I think I have found a large element that is as good or maybe better than TP. It is Scott center pull paper towels. I got them from www.viking.com stock #G11-BZL01032. My large housing takes several elements from several companies. Some have about the same filtering ability as paper towels. Some are just large pleated paper elements. The Scott elements are expensive compared to regular paper towels but they are concentrated paper fibers. It looked like I was going to do some engineering to make the 8" by 15" element fit the housing. The stock element is 7 1/2" by 15" My filter supplier has a slightly larger and longer housing that will handle the longer and larger element. I wasn't looking forward to rolling about 12 rolls of TP together. The elements are 8" by 8" I drop two in. When you are dealing with paper fiber elements a good test is how much the element weighs. It would take several rolls of Bounty Big rolls to equal one of the big elements. They are messy to change but not more than other paper towel filters. They don't need to be changed very often like 30,000 on my old Ford diesel.
Ralph
Ralph
