Originally Posted By: aquariuscsm
Doesn't coolant also lubricate the water pump?
No i doesn't. In fact the seals used in a modern water pump are specifically designed to resist ethylene glycol.
The bearing is sealed and the coolant/antifreeze plays no role at all as far as the seal or bearing is concerned, not even to preserve the seal in some way.
http://www.skf.com/group/products/seals/...eals/index.html
OP
Straight coolant is is not very effective it is supposed to be mixed to be most effective. 50/50 mix with distilled or deionized water is the most efficient mixture.
electrolysis is a serious issue and is even a bigger problem with so many dissimilar metals and additional electrical components being used in cars and engines.
Product like water Wetter and similar are for racing so the engines can take advantage of waters better heat transfer, while it may offer some corrosion inhibitors its primary job is to reduce surface tension of the water and prevent cavitation in the heads.
Not really for everyday usage.
http://www.erareplicas.com/427man/cooling/electolysis/
OP
