Originally Posted By: hcbarger
I have decided to start drain and fills every other oil change on mine and the wife's 07' and 08' Mazda 6's. The car specs for Mercon V. I can get Kendall Mercon V right here at work but I would prefer a synthetic. Any recommendations would be appreciated. Even if that means reccomending I buy the Kendall Mercon V here. Thanks in advance.
I had an 07 Maz6i with the 5speed atx and Amsoil ATF was much better than the factory stuff when cold. Skip the D&F and do 1 flush with it (3 gallons) on a proper machine in a shop and don't look back. Keep it in for however long you feel like, the filter in that trans is just a simple screen anyway.
Amsoil says service life is:
"Recommended for 50,000 miles in severe service* and 100,000 miles in normal service;* or per vehicle manufacturer-recommended intervals, whichever is longer."
So instead of flushing every 30k like the manual says you can pick anywhere from 50-100k based on how worried you are.
I autocrossed my car and it never skipped a beat. Tail of the dragon? Not a peep. In cold weather (teens) the first shift is sluggish but from there on out you're good. Stock fluid would be surgy/delayed for much longer.
