It is time that I change my rear end fluid and drain and fill my transmission and change the filter.
According to the owners manual, we are supposed to use 75W-90 Syn gear lube. Does anyone use the GM lube or is aftermarket OK? If aftermarket is OK, which one, Mobil 1, redline, schaeffer? Even though I have the 2WD version with the traction control package, doe I need the friction modifier? GM's gear oil is very $$$.
One diff shop in my area claims that GM syn is too thin and he has seen many come in fried. The shop works on a lot of high end and race differentials in the Houston area. Comments???
How about transmission fluids. The owners manual just spells out Dex III. Is the standard Pennzoil Dex III OK or does GM use a special Dex III Syn???
