OVERKILL
$100 Site Donor 2021
Originally Posted by JosephA
Quote
I need some further clarification here.
Are you saying the lifter body rotated/twisted? Because the body is a single piece, so the only way that is happening is if the (plastic) guide isn't keeping it straight, and that problem wouldn't be MDS-specific, since the same retaining unit/guide is used for both MDS and non-MDS lifters.
Yes, the lifter is twisted. Look at the image I posted earlier and you will notice the lock pin is not centered with the hole, and the bottom roller is not quite in line with the top half of the lifter.
The body should be one solid piece, without a machining problem, it should be impossible for the lifter to become out of alignment with itself. Your picture shows that the internals have shifted/twisted, which I noted, but unless that's a two-piece body...?
If it is indeed a one-piece body, like the diagrams I have posted show, and every conventional roller lifter I've ever handled, then the top being out of alignment with the wheel can only be due to machining/manufacturing error. Now, the body being twisted isn't a requirement for it to twist in the bore and run off-centre/on an angle, that just requires wear or failure of the plastic guide mechanism.
Ford used dog-bone style retainers, which were metal, and tended to work quite well. I believe GM did the same on the SBC, not sure what they use on the LSx engines off the top of my head. Nylon for something as important as lifter rotation mitigation strikes me as a poor choice.
Quote
