Check out this bottle of Quaker State SUPER BLEND from the 1990s. "The intelligent oil." Not sure if the oil is intelligent, but the bottle has an ingenious vented neck design for smooth pouring. There's a friendly congratulatory message from the Chairman/President/CEO, Herb Baum, on the back of the bottle. Mr. Baum want's the purchaser to feel good about having purchased one of the "finest motor oils in the world." The bottle also has instructions to avoid polluting, return used oil to a collection center, and recycle the bottle. Quaker State was headquartered in Oil City, PA at the time.
Q™
Quaker State®
The intelligent oil™
FOR LONGER ENGINE LIFE
SUPER BLEND®
SAE 10w30
AMERICAN PETROLEUM INSTITUTE
CERTIFIED
FOR GASOLINE ENGINES
MOTOR OIL
API SERVICE SH,SG/CC,CD
1 qt./946 mL
QUAKER STATE®
Dear Valued Customer:
Congratulations! You have just purchased one of the finest motor oils in the world. With our advanced formula, no other conventional oil keeps your engine protected better or longer against wear and tear, heat, or friction. By using Quaker State and changing your oil properly, you can make your engine last longer. Thank you for using Quaker State.
Herb Baum
Chairman, President, and Chief Executive Officer
Exceeds North American warranty requirements for U.S., European and Japanese cars and light trucks--GASOLINE, DIESEL and TURBO CHARGED. Passes CCMC engine tests and JAPANESE valve train wear test. Check owner's manual for proper SAE grade and oil change intervals.
API SERVICE SH/CD
ENERGY CONSERVING II
SAE 10w30
SAE 10w30
API SERVICE
SH,SG/CC,CD
MADE IN U.S.A.
DON'T POLLUTE
CONSERVE RESOURCES
RETURN USED OIL TO COLLECTION CENTER
RETURN BOTTLE TO RECYCLING CENTER
WARNING: Continuous contact with used motor oil has caused skin cancer in animal tests. Avoid prolonged contact. Wash skin with soap and water. Launder or discard soiled clothes.
©1995 QUAKER STATE CORPORATION, OIL CITY, PA 16301
SUPERBLEND® 10w30
073102012547
