Can the Purolator red oil filter do a 6K oil change interval?It’s rated for 5k.Thank you
Purolator seems to be problematic on these forums with torn filter media. I certainly would not intentionally run any filter past what it is rated for, especially a Purolator.Can the Purolator red oil filter do a 6K oil change interval?It’s rated for 5k.Thank you
I am still seeing listings at 5k so his may be that. The puro one was 10k...10k miles per website:
Purolator® Oil Filters
The proven filtration performance of original Purolator® Oil Filters is best used for normal driving conditions, habits and oil change requirements.www.purolatornow.com
Even if the can says 5k miles, it wouldn't bother me to run it out to 6k miles.
You have to ask it...Can't imagine using a filter that is rated for 5K; that screams "marginal" and how does the filter know how many miles you've driven?
Prudent advice, I agree tasch72.If the specific filter has a silicone ADBV, yes I would run it to 10k. Otherwise, I would stick to 5k with a nitrile ADBV.
I keep reading this but, have there actually been any documented cases of filter media tear on purolator one filters in the last 3 years?Purolator seems to be problematic on these forums with torn filter media. I certainly would not intentionally run any filter past what it is rated for, especially a Purolator.
I've beeb using pyrolators off and on since just before 2010 never have had a tearolator YMMV.I keep reading this but, have there actually been any documented cases of filter media tear on purolator one filters in the last 3 years?
I'd be afraid of a Pyrolator starting on fire.I've beeb using pyrolators off and on since just before 2010 never have had a tearolator YMMV.
It's the automatic ADBV burn test feature, lol.I'd be afraid of a Pyrolator starting on fire.
