Originally Posted By: volk06
Did you double check to make sure the seal gasket of the last oil
filter came off? This is a common sign of the dreaded double gasket too.
I trashed the old one so I can't check at this point, but I did not see anything out of the ordinary during the change. This was my first time using the newish Purolator One, which feels somewhat different than the old PureOne. I noticed that the seal had a somewhat powdery coating but assumed it was meant to be there, so i smeared it with oil and installed. As I mentioned, I made it hand tight; I could not turn it tighter by hand the next day, but could with a wrench.
This is the first time in 25 years+ that I had one leak at the seal! I will probably go back to fram ultra for the next change, mostly because I have never had a problem with them.
