Originally Posted By: ecotourist
Originally Posted By: supton
Originally Posted By: CKN
New tech phobia is alive and well on BITOG.
True, but with the help and guidance of BITOG my last auto purchase was a...twenty year old Camry. I like to think I will get low cost per mile. And when it does break down, it'll be simple to fix. And simple to jerry rig in case whatever it needs has gone obsolete. And if whatever it needs is outside my range of ability, cheap for someone else to fix.
I guess we'll see how this tech goes....
...Staying behind the tech curve is safer & cheaper.
I have to confess I'm a bit worried about all the new safety gear. When it works it'll be great. But when your car can brake and steer on its own, all sorts of things could go wrong. As one example (according to CU) the problem with lane control is that when you try to steer around a cyclist, the car steers you right back into your lane. Seems you get around this problem by signalling a lane change - just don't ever forget.
And that assumes it will stay working more or less as it should.
Or as we used to say, "it's all that reliable electronic stuff."
Well, it only steers you back into your lane if you let it.
We have a 2017 Toyota with the Safety Sense or whatever they call it.
If the lane departure system is turned on, it will warn you and nudge the wheel. But you can easily override it by continuing the lane change. And of course, it will not bark at you if you signal the lane change.
