The write up says “ for neglected systems”. I would not use it in vehicles that were kept up to date with changes.
The main thing is to have a plan to flush out of the engine after it did it's thing. Putting a garden hose in the radiator neck or the bottle doesn’t get the fluid out of the block.
Here is a Prestone flush kit. To install it you have to cut one heater hose line. The kit has three sizes of tees. Some people don’t like them because they add two clamps to the system and also the plastic T can be a liability after a lot of years. I believe you need a standard radiator top outlet to work. Some vehicles don’t have that.
Alternatively you can do several rad fills with distilled water and run it through the engine. It will get most of it out but not all. I’d suggest to run each session until the top rad hose is hot to make sure the thermostat is open and water is circulating from the block and through the radiator.
By the way, letting the water run down your driveway into the street drain in Edmonton would be illegal. You need to hook up a hose to the outlet and catch the water in some jugs and dispose of it properly.
Here are some pics of a Prestone kit. Enjoy.
View attachment 218479View attachment 218480View attachment 218481View attachment 218482
