I have a pickup truck that keeps going through power steering racks. The truck is an 06 ddoge dakota with 60,000 miles on it. Throughout it's life it has had 2 power steering racks replaced due to a leak at the inner tie rod end seal. The third and current rack has just developed the same issue.
The truck is running the correct sized tires, has the factory suspension, and is only used on-road.
I have come to the conclusion that the racks themselves are junk, with poorly made seals. Only one company makes the racks so I have no options.
I am 0-3, so replacing the power steering rack is just a bad investment. What is the opinions on Lucas Stop Leak? Will that fix teh seal problem I am having? What do you think the issue can be? Why would the racks keep failing? The fluid was completely flushed and replaced after each rack was replaced, and currently the fluid (ATF4) is clean and in great shape.
Right now the leak is extremely slow, never drips out of the boot, but I am sure it will get there.
