A little background, this engine has for years had slight coolant seepage (lower gaskets). In mid 2010 the vehicle usage had changed from a daily driver to a short tripper.
In early 2013 the upper manifold gasket developed a vacuum leak so at this time I did lower intake gaskets and buttoned it all up. Care was taken to not let any coolant into valve galley and a quart of oil was poured down galley as a precaution. Oil was changed with the cheapest I could find (Peak 5w30 IIRC) and ran for 500 miles. This analysis is the second change after the Peak oil. From my research the Peak uses sodium as an additive
although I can't seem find how much. I also haven't added a drop of coolant since the repair.
I'm a little surprised that Sodium and iron numbers. Questions/comments welcomed.
Code:
OIL TYPE PP PP PP PP PP PP GC GC GC GC M1 M1 M1 M1-EP M1 M1 M1 M1
OIL GRADE 5w30 5w30 5w30 10w30 5w30 5w30 0W30 0W30 0w30 0w30 5w30* 5w30* 5w30 5w30 5w30 10w30 5w30 10w30
MILES IN USE 5.4k 5.6k 4.9k 4.5k 4.4k 4.6k 4.4k 4.3k 4.4k 4.6k 4.8k 5.5k 5.7k 5.6k 6.2k 8.7k 7k 5k Uni Avg
MILES 223.7k 207.9k 191.9k 182.2k 177.7k 173.3k 164.8k 156.8k 152.5k 148.1k 143.5k 138.7k 133.2k 128k 121.9k 115.7k 107k 95k
SAMPLE TAKEN 8/31/14 4/27/12 3/19/10 7/26/09 4/19/09 1/23/09 8/2/08 2/9/08 10/27/07 7/21/07 4/7/07 1/6/07 9/2/06 5/7/06 1/7/06 8/21/05 2/28/05 6/6/04
ALUMINUM 3 4 2 3 2 3 2 3 2 3 4 3 2 2 3 2 2 2 3
CHROMIUM 0 1 1 0 0 1 1 1 0 1 1 1 0 1 1 1 1 1 1
IRON 50 34 11 8 9 13 12 14 12 17 24 19 14 16 22 18 17 13 14
COPPER 13 13 11 15 9 12 12 14 14 13 12 14 14 13 15 17 13 16 18
LEAD 9 11 5 5 4 8 18 14 22 19 10 14 28 11 23 42 5 5 7
TIN 0 0 0 0 1 1 0 2 0 0 0 0 1 0 0 1 2 1 1
MOLYBDENUM 54 47 53 54 53 50 3 2 6 18 91 84 82 72 85 77 60 70 41
NICKEL 0 1 1 1 0 1 1 1 0 1 1 2 0 0 1 0 0 1 0
MANGANESE 1 1 1 2 0 0 1 0 0 0 0 1 1 0 0 0 0 0 0
SILVER 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
TITANIUM 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
POTASSIUM 9 9 8 12 17 22 9 16 6 10 20 9 6 6 11 17 11 7 7
BORON 3 23 25 30 26 25 4 3 5 12 57 60 51 122 55 106 104 150 45
SILICON 14 11 7 7 5 7 8 8 7 9 11 11 11 11 12 9 9 11 11
SODIUM 31 42 39 26 36 48 23 35 19 24 46 20 6 9 10 14 12 19 11
CALCIUM 2379 3076 3277 3026 3067 3267 2494 1896 1866 2013 2564 2308 2731 2294 2705 2780 2302 3134 2128
MAGNESIUM 17 16 17 22 34 131 593 563 525 424 20 15 14 19 19 19 25 23 131
PHOSPHORUS 698 656 697 742 703 766 981 870 842 797 737 658 673 698 677 745 592 831 741
ZINC 874 759 915 979 870 1082 1251 1066 1082 1041 932 818 834 870 838 946 694 983 901
BARIUM 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
INSOLUBLES 0.1 0.3 0.3 0.3 0.3 0.3 0.3 0.3 0.4 0.3 0.3 0.3 0.3 0.3 0.3 0.4 0.4 0.5
WATER 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0.1 0
FLASHPOINT ºF 400 405 390 420 400 385 405 415 415 395 405 395 390 370 395 425 385 375
SUS VIS 210ºF 57.6 58 60.9 60.7 59.5 61 66.9 67.7 66.8 67.7 63.6 64.4 63.2 62.5 61.8 65.3 63 62.2
cSt VIS 100°C 9.54 9.64 10.47 10.41 10.08 10.51 12.13 12.35 12.11 12.33 11.22 11.44 11.11 10.91 10.7 11.68 11.05 10.8
* 4 qts M1 5w30 + 1 qt M1-EP 15w50
Code:
