Hi there!
The term "moly" comes in many forms and when used in lubricants, it can be a solid or a soluble liquid. The typical "moly" that is used and soluble in motor oil is Molybdenum Dithiocarbamate (MoDTC) or Dialkyldithiocarbamate. One of its major function or use in motor oil is a friction modifier. However, it also may be used as an anti-wear and/or antioxidant.
Pennzoil does use moly in our formulations. It varies depending on the application/specification because reduction of friction is not dependent on moly alone. There are other types of friction modifiers out there that are not moly-based, thus high concentration of moly in a motor oil is not always beneficial to your engine. Motor oil requires a balance of detergents, dispersants, friction modifiers, viscosity modifiers and other critical additives to give you the complete protection for the extreme conditions that the engine goes through.
