Oil in use 4 months. 35% highway miles, 65% city miles. Miles on unit 41,063. No make-up oil. Good mix of ambient outside temperatures. Analysis by Blackstone on 5-12-04.
My comments: Ho-hum.
Blackstone comments: Your viscosity was a little low again this time, and now the oil does appear to have some fuel dilution (note the low flashpoint). Insolubles were still low at 0.3%, and no coolant or water contamination was found. TBN was the same as last time at 1.2, so not much active additive is remaining. Wear metals held steady or dropped, so the lower viscosity has not been a problem so far. We would suggest staying with your current change interval and resampling to monitor the flashpoint (% fuel). It's probably from idling or city driving & will disappear.code:
ELEMENT TESTED UNIV
ALUMINUM 3 4
CHROMIUM 1 1
IRON 9 20
COPPER 4 7
LEAD 1 2
TIN 0 0
MOLYBDENUM 66
NICKEL 1
MANGANESE 1
SILVER 0
TITANIUM 0
POTASSIUM 0
BORON 53
SILICON 7
SODIUM 2
CALCIUM 1835
MAGNESIUM 5
PHOSPHORUS 685
ZINC 937
BARIUM 0
SUS @ 210 55.7 (high 20 - started life at SUS of 63 per Pennz PDS)
FLASH 340
FUEL 1.3%
AF 0
H2O 0
INSOLS 0.3%
