Originally Posted By: BobFout
Originally Posted By: nobb
I've found that with age, spring clamps need to be positioned in exactly the same indents they were originally positioned on the hose otherwise you'll get leaks when pressurized up.
If that did happen...would replacing the clamp fix the problem, or would it warrant replacing the hose?
nobb is the correct. If this occurred, you will need to replace the hose.
