Can you elaborate why these 3 emission control devices does not decrease emission? What is the purpose of having them?
Which emissions?
The supply side of fuel makes emissions that dwarf what your car emits in pollution on a per gallon delivered basis if we include VOC from spoilage and spills and heavy metal pollution from extraction.
This isn’t mentioning random stationary industrial pollution sources are nearly unlimited in certain cases and usually don’t have to follow as stringent of requirements as a vehicle.
So US Centric is nearly 100% focused on one specific emission with a distant second on sulphur/particulate and this focus is mostly on road going vehicles and power plants, distant 3rd being homes.
Further we measure emissions not by weight per mile but by percentage.
The issue is not whether those devices decrease emissions percentage in the exhaust, they certainly do and in an inversion layer are needed.
But outside that inversion layer is it worth burning 20% more fuel alongside the resources and pollution created to maintain the devices in question including the fact that the supply side “creating” your gallon of fuel delivered dwarfs your car’s emissions?
AKA to reduce primarily NOX and some VOC (in the summer at least) we burn 20% more fuel which creates 20% more co2 and a token amount of carbon monoxide.
Open up Nox limits, outside inversion layers and using the existing Pollution controls but tuned differently can save 20% fuel, despite claims to the contrary Nox does go up in lean but with any cat the amount it goes up is far less than the 40’s era chart everyone posts suggests.
Holistically the only way to reduce overall pollution is to use less fuel and less energy but nobody likes that answer.
That is even true of Bev, we need to use less energy to make less pollution whether the pollution is in the air, water ground or in my neighbors backyard instead of mine doesn’t matter.
All energy conversion devices cause some form of pollution whether it’s during use or during assembly in the air, in the ground or in the water, still makes a form of pollution.
