Originally Posted By: Quest
Originally Posted By: dlayman
7th gen Civics are known for head gasket failure, main symptom being random overheats. That doesn't quite sound like what you have though, but a possibility.
That is only true if the owner lets their 7th gen civic engine overheats first.
There's a cause and a consequence. The cause is mostly overheating but most owners or posters won't mention that....
Q.
I guess it depends on how you define overheating. On my car, I noticed the temp (dummy) gauge going slightly above half way on occasion, never near the red zone, and took it it a good mechanic. He had a very hard time replicating the symptom, but did find a small amount of exhaust gas in the coolant, and was able to diagnose the gasket failure. When he removed the head, the gasket was basically rotted out. It was replaced and no problems in the 30k miles since. I wouldn't define that as an overheating event as it was still within acceptable operating parameters. This generation of Civic is about as bad the bad Subaru generations. There are two types of them, those that have had head gasket failures, and those that will.Fortuantely it's not a terribly expensive fix on the Civic.
Certainly an overheating event would put the head gasket at risk, but not all gasket failures are preceded by overheating.
