As to the packaging of the engine...look at the ford V-8...
Look where the head gasket part line is, which is the end of the piston stroke, and look how much head there is...nearly another block/crank's worth.
Nothing says the opposed piston engine needs two pistons of equal stroke, at the limit of short stroke for the second crank, it can be functioning mainly as a valve mechanism, less as a power piston (still power there, 'though).
* Mount the bottom crank to the gearbox, and have a slanted 3 cylinder (like one bank of the V-8 shown).
* make it flat, and obtain the drive off an intermediate timing gear between the two cranks (have read a few papers on investigating primary transmission drive off camshafts, so it's not out there).
