Originally Posted by Gokhan
What I like about 5W-20 is that it uses a thicker base oil than 5W-30 does. So, while the HTHS viscosity, which is relevant to the wear protection of the bearings, is a little less, the valvetrain, timing chain,
and rings and liners will have less wear with 5W-20 than with 5w-30 because the base oil is thicker.
Not so sure about that. There's been quite a few papers that show less wear on most engine parts with higher HTHS viscosity. Looks like when the HTHS starts going below 2.6 cP is when the wear really starts to increase. Most xW-20 weight oils have a HTHS around 2.6~2.7 cP ... so basically they are starting out real close to the point on the graph where the wear starts increasing noticeably - so what happens with a lot of fuel dilution and/or oil shearing to decrease the viscosity even further?. Also, higher RPM has a big effect on ring wear ... so cruising around like a grandpa will result in less wear.
Let's not read too much into one plot, especially with no additional info on the test oils having been provided.
If you look at the plot, HTHS viscosity = 2.6 cP is producing the least ring wear -- the effect being drastic at 3000 rpm and 6000 rpm -- at virtually all rpms. So, perhaps this oil has a thicker base oil than the 3.1 cP oil.
We have no information on the 2.2 cP and 2.4 cP oils -- they may also be using very thin base oils as well. Therefore, we don't know if the rise in the wear is because of the fall in the HTHS viscosity or the fall in the base-oil viscosity.
I'd be interested in the mechanism for increased wear in timing chain/valve train, based upon your base oil explanation. Why does the 20W perform better?
