Engine: Onan Marquis Gold 5500
Oil Type: Onan 15w40
OCI: 100 HRS on oil 324 hrs on the GenSet
Fuel Type: Gas
Aluminum 2
Chromium 0
Iron 7
Copper 2
Lead 1
Tin 0
Moly 83
Nickel 1
Manganese 0
Silver 0
Titanium 0
Potassium 0
Boron 91
Silicon 4
Sodium 0
Calcium 2818
Magnesium 7
Posphorus 903
Zinc 1234
Barium 0
SUS Viscosity @ 212*F
Should be 69-82
Tested 79.7
Flashpoint should be >405*F
Tested 425*F
Fuel dilution in %
Should be Tested 0.5
Insolubles in %
Should be Tested 0.2
No water/Antifreeze
Blackstone comments: No problems showed up in the initial sample from this generator. All wear read at or below averages for this type of engine, which is a very good indication of normal wearing parts. Universal averages show normal wear after 75-100 hours use on the oil. Insolubles *oil oxidation due to heat, use, and blow-by} were low, showing excellent oil filtration. No fuel or anti-freeze was found. Silicon was normal, so your air filtration is fine and the TBN was strong at 8.7, showing plenty of active additive left. 1.0 is low. At 324 total hours, this engine looks great.
This genset was operated in cold and wet conditions in early spring, and was also used most of the time in Southern California at Glamis in a dust storm/high heat for two weeks. I think the oil held up fine for the conditions. I've used up the last of the Onan oil, GC 0w30 is in it now. Haven't completly decided what oil I'll use next. I may continue with the GC if it turns out these kinds of numbers.
Fuel Type: Gas
Aluminum 2
Chromium 0
Iron 7
Copper 2
Lead 1
Tin 0
Moly 83
Nickel 1
Manganese 0
Silver 0
Titanium 0
Potassium 0
Boron 91
Silicon 4
Sodium 0
Calcium 2818
Magnesium 7
Posphorus 903
Zinc 1234
Barium 0
Should be 69-82
Tested 79.7
Tested 425*F
Fuel dilution in %
Insolubles in %
No water/Antifreeze
