Originally Posted By: Hollow
Vehicle: 2003 Subaru Outback with 163,000 miles.
Car is my wife's daily driver. It is needing a goodly amount of repairs due to age/miles/issues from being in the rust belt for 12 years before escaping. Car is paid off, my wife likes it, and want to keep it as long as we can.
Issues and needs:
-Exhaust leaks all over the place as the entire system is rusting apart. Eventually needs replaced from engine to exhaust tip. Mostly patched together currently with hose clamps and exhaust tape.
If you don't believe this is a serious safety issue you are mistaken, any mechanic who says its not dangerous is either a total hack, a moron or both and that is a fact
Quote:
-Drivers side headgasket has let go, leaking oil and coolant externally. Not planning on repairing this, just keeping fluids topped up.
Common on Subaru, don't fix it and there is a very good chance it will need an engine sooner than later due to coolant in the oil.
Quote:
-All suspension parts are factory and could stand to be replaced eventually. No clunking or grinding, but bumps are getting more notable and one strut is starting to leak, along with front ball joints boots split, both control arm bushings leaking.
163K on original parts in the rust belt, torn boots and leaking strut. It needs a front end rebuild. bushings cant leak they wear out but are not liquid filled.
You say parts and labor so apparently you are paying for this to be done.
Quote:
-Electrical short in passenger door affecting lock and speaker. Haven't been able to figure this one out yet, it's intermittent.
The least of your worries.[/quote]
Quote:
-New front bumper support needed, my fog lights are cracked and the bumper support is too badly rusted to mount new ones. Repair cost: $100ish at a junkyard.
Non issue
Quote:
]MOST of these are age/miles/rust related. Replacing EVERYTHING will run close to $2000 in parts and labor, but I also don't want to set money on fire (see ignoring the HG and exhaust until they become critical).
The exhaust is critical right now and so is the HG if you want to keep this car. Ball joints with torn boots wear quickly and leaking struts are a safety item as it increases braking distance. The whole car is critical and if your paying for labor repairing this is close to insanity and definitely setting the money on fire.
I know this is not what you want to hear but these are the facts.
