Originally Posted By: JHZR2
Get it running on carb cleaner then override the governor so it revs to the moon. It's just gotta suck a loogie through the carb, once that's done you're good to go.
That was my initial thought and hope, there is a throttle lever on the machine, but when set to the fastest position, if I play with the governor, there's no more room for motion of the throttle plate inside of the carburetor. It is as wide open as possible when I have it at the fastest setting, so I don't think that I can start the engine with the speed any faster than it is already.
Yeah but if you start it the governor will slow it down.
I'm assuming it'll run better than it is, I think. This works with stuff that kinda sorta some days runs on gas.
I usually get into this predicament by taking the air filter off and giving it a spritz of starting fluid, cranking it, getting it running, then spraying more in (good way to burn your eyebrows off in a backfire) etc and getting it over-revving to the point where gas starts flowing from all the intake vacuum. You could probably also prop the throttle open with a pen or something but this seems dangerous.
IDK if this even has an idle circuit, it's an edger, it's what it does. Real simple.
