Hello all I purchased a 1999 gmc safari van with 140,000 about a year ago, as soon as I got the van home I changed the oil with mobil1 high mileage 10w30. before I did the oil change the van had around 60Psi cold idle, 40 psi warm.
But about a week after the oil change the oil pressure started dropping I didn't pay much attention to it as people told me the chevy oil pressure sending units were unreliable.. But another week passed and the motor started feeling strange like I was pulling a trailer. At this point my oil pressure gauge was reading 30psi cold, 10psi or less at warm idle. Well finally @ 1200 miles on the mobil1 high mileage synthetic the motor spun a rod bearing!
So I decided to replace the engine myself! As I just bought the van and wasn't about to lose $3500 I payed for it. But This just seemed so strange for a healthy engine to just eat itself AFter a premium oil change! So I dropped the oil pan expecting to see the oil pump screen plugged with deposits that the synthetic oil had broken down. But it was the opposite the oil had a Silver color and lots of metal on the magnetic drain plug. But the motors internals were a pretty gold color! Hmm mm confused and determined I tested the oil pump and It worked just fine! Soo yeah idk.
But at this point I still needed a motor so I got one from my local pick and pull, I got the motor from a 2000 chevy astro with the newer roller cam & roller rockers. While I was in the motor I changed all the seals and installed a melling hi volume oil pump, I also removed the oil cooler as there prone to leak. I then got it installed in the van. I now have 75-80psi cold idle and 40-50psi warm idle with 5w30 mobil extended performance.the oil pressure seems like more than enough, so I was wondering if I could get away with running thinner oil maybe 0w30 or 5w20? And thinking of switching to amsoil so I can extend my oil change intervals? I searched but I couldn't turn up any results for extended oil changes with the 4.3 vortec, just how long can i extend the interval and what brand?
& Thank you for taking the time to read this
