Originally Posted By: ksj4477
Originally Posted By: WyrTwister
What does the owners manual recommend for your temperature conditions .
What kind of oil pressure are seeing ? Cold start ? At operating temperature ?
Can you look up & determine if it has roller lifters or flat lifters ? Looking on AutoZone.com , looks like flat lifter ? You may need oil with elevated zinc levels ?
No owners manual that I have found yet. It idles at 30 psi but doesn't increase when i give it a little throttle so I'm wondering if the gauge or sender is messed up. It won't be run in any conditions under 45 degrees. It can get up around 100 in the summer time here. Flat tappet lifters, I believe the engine is completely stock.
Might consider installing a mechanical oil pressure gauge ?
We have a 1991 Caprice with a 5.0l , completely stock . Looked it up & it does have roller lifters . So any modern dino oil of name brand should be fine for it ( rarely gets driven ) . With the overdrive automatic , it got good MPG back when Dad was still alive & it got driven . Geared pretty high . I suspect yours may have a lower ratio differential ?
I think the 5.0l is / was a pretty good engine , just not high horse power .
Best of luck too you ,
