When doing your oil changes do you always check for left over gasket material on the mating surface? Left over gasket? Do you wipe the mating surface down? Do you always oil the filter gasket? Do you use clean or used oil to lube the gasket?
I wipe the mating surface checking for gasket material. I always oil the gasket. I use either new oil or some used oil from the drain pan or used filter.
