Oil choice for 2021 Volvo wagon?
Would like to see if there are any ACEA or API approvals called out in the manual before I consider recommending something.
The only published specification is a long drain, Volvo-only, code. No ACEA or other specifications are listed.
So, the Total, if it meets some sort of Euro long drain specifications, and I suspect it does, should be fine.
the 10w60 works good in my john deer.
here is the data sheet https://totalenergies.com.au/system...tz_ineo_xtra_dynamics_0w-20_trp_202103_en.pdf
Vehicle is actually a XC-90. T6 sub model
Trevor approved 😍
