Oil change tech used incorrect drain plug gasket
St. Louis, Missouri
I just did my annual oil change today, and guess what I found. Last year, the oil change tech at my Toyota dealership (Fusz Toyota) in St. Louis, didn't use the correct oil drain plug gasket. He used one that was smaller than the correctly sized gasket.
I've done my own oil changes for the past 8 years, except for one time last year when I decided to have the dealer do it since I was already there for tire repair or something. I wonder if the smaller sized gasket that the Fusz Toyota Dealership tech used is responsible for the darkening of my garage's concrete floor directly below the car's oil drain plug? I know the oil didn't LEAK onto the garage floor this past year, but the floor has become very discolored, perhaps due to imperceivable MISTING from a too-small drain plug gasket when the oil's been parked hot?
Schucks, when you take your car to the dealer, you expect things to be done right and by the book. I'm glad I changed my own oil again today, and didn't let the dealer do it.
da fuq?
Originally Posted By: oilpsi2high
I don't think oil is going to mist out of your oil pan. It probably has been dripping if anything.
I think I understand what you're saying, Oilpsi2high, but I've never seen the floor wet with oil, just gradual darkening of the floor's color over a year's time.
I am thinking the two are not connected.
How is it too small? To thin? Outside diameter smaller that drain plug outside diameter?
Obviously the inner diameter could not be too small or the washer would not have fit the drain plug.
I think the drain plug gasket probably did it job just fine.
I don't know if the oil tech's gasket is thinner (I should have looked more closely), but the outside diameter is much smaller.
Also, maybe the tech didn't tighten the drain plug enough, or a combination of incorrect tightening/torquing and drain plug gasket size.
da fuq?
Lol I said the same thing in my head when I read it
All it takes is that one time.
"If you want it done right, do it yourself."
There's a lot of truth to that old saying.
Originally Posted By: stchman
Either an oil drain plug drips or it does not. Oil does NOT mist out of a drain plug.
Was the drain plug wet?
I don't think the drain plug was wet. I don't recall if I touched the plug before applying the socket wrench.
I agree. Oil does not mist from a leak. If its the plug You should see an actual drop of oil on your concrete.
Otherwise the discoloration is more likely from your ac dripping condensation that has picked up some oil residue from the road or engine bay detailing or random oily-ness. The water spreads out the oil particles then evaporates so you dont see an actual drop
It sounds like neither of these things happened. If it were a bad seal you would have seen some oil somewhere over the course of the year, and probably had to add some oil to replace what was lost. I wouldn't be so harsh on the dealer. Doesn't sound like there is a problem.
Thank you Raytseng, 901Memphis, Donald, Stchman, and everyone for your very interesting detective work. I will investigate under the car tomorrow morning.
